Is any kown Issue with ICX6450 stacking
Hi All,
I'm using ICX6450-48 port 2-stacked switch in a my local environment, all stack ports are 10G.
I have configured stack ports on both switch units in trunk mode (Trunk1: [1/2/1, 1/2/2],
Trunk2: [1/2/3, 1/2/4]).
I have observed few link flipping issues on ports 1/2/2 and 1/2/4. In show statistics command, i see some InErrors as well as CRC. I exchanged stack cables even replaced units, but problem still persists.
Is there any issue with stacking in ICX6450. I am using firmware 08.0.30.
3 REPLIES 3
BenBeck
Can you provide the following:
show stack
show media
show media eth x/y/z (for stack ports)
show stat eth x/y/z (for stack ports)
show version
show run
dm statistic
It may just be a good idea to open a TAC case for this one, but I'm happy to help as well.
Hi Ben,
Thanks for looking in this issue.
Please find below command output requested by you,
1> show stack
T=188d14h20m19.5: alone: standalone, 😧 dynamic cfg, S: static
ID   Type          Role    Mac Address    Pri State   Comment
1  S ICX6450-48    active  cc4e.24db.9400 128 local   Ready
2  S ICX6450-48    standby cc4e.24db.9200   0 remote  Ready
    active       standby
 =2/3| 1 |2/1==2/3| 2 |2/1=
Standby u2 - protocols ready, can failover
Current stack management MAC is xxxx.xxxx.xxxx
2> show media
-- snip --
Port 1/1/1:  Type : 1G M-C (Gig-Copper)
Port 1/2/1:  Type : 10GE Active Twinax   1m (SFP +)
Port 1/2/2:  Type : 10GE Active Twinax   1m (SFP +)
Port 1/2/3:  Type : 10GE Active Twinax   1m (SFP +)
Port 1/2/4:  Type : 10GE Active Twinax   1m (SFP +)
Port 2/2/1:  Type : 10GE Active Twinax   1m (SFP +)
Port 2/2/2:  Type : 10GE Active Twinax   1m (SFP +)
Port 2/2/3:  Type : 10GE Active Twinax   1m (SFP +)
Port 2/2/4:  Type : 10GE Active Twinax   1m (SFP +)
-- snip --
3> show statistics
Port             In Packets       Out Packets       In Errors      Out Errors
-- snip --
1/2/1           38939804407       38974460322            3998               0
1/2/2           40081232299       39038419529           45635               0
1/2/3           38932347483       38972475777          164239               0
1/2/4           38886919228       40060803557          137287               0
2/2/1           38972425084       38932490713            7956               0
2/2/2           40060758864       38887041223            3837               0
2/2/3           38974380267       38939731596            2861               0
2/2/4           38999040397       40081192297        38583818               0
-- snip --
4> show version
  Copyright (c) 1996-2015 Brocade Communications Systems, Inc. All rights reserved.
    UNIT 1: compiled on Mar 30 2015 at 18:25:06 labeled as ICX64R08030
                (9693416 bytes) from Primary ICX64R08030.bin
        SW: Version 08.0.30T313
    UNIT 2: compiled on Mar 30 2015 at 18:25:06 labeled as ICX64R08030
  Boot-Monitor Image size = 786944, Version:10.1.05T310 (kxz10105)
  HW: Stackable ICX6450-48
UNIT 1: SL 1: ICX6450-48 48-port Management Module
         Serial  #: BZU3222L063
         License: ICX6450_BASE_ROUTER_SOFT_PACKAGE   (LID: dbwIHHHnFLI)
         P-ENGINE  0: type DEF0, rev 01
         P-ENGINE  1: type DEF0, rev 01
UNIT 1: SL 2: ICX6450-SFP-Plus 4port 40G Module
UNIT 2: SL 1: ICX6450-48 48-port Management Module
         Serial  #: BZU3220L094
         License: ICX6450_BASE_ROUTER_SOFT_PACKAGE   (LID: dbwIHHFnFOJ)
UNIT 2: SL 2: ICX6450-SFP-Plus 4port 40G Module
  800 MHz ARM processor ARMv5TE, 400 MHz bus
65536 KB flash memory
  512 MB DRAM
STACKID 1  system uptime is 188 day(s) 14 hour(s) 20 minute(s) 18 second(s)
STACKID 2  system uptime is 188 day(s) 15 hour(s) 1 minute(s) 13 second(s)
The system started at 12:35:57 GMT+00 Wed Nov 29 2017
 The system : started=warm start         reloaded=by "reload"
My stack unit ID = 1, bootup role = active
5> show run
Current configuration:
ver 08.0.30T313
stack unit 1
  module 1 icx6450-48-port-management-module
  module 2 icx6450-sfp-plus-4port-40g-module
  priority 128
  stack-trunk 1/2/1 to 1/2/2
  stack-trunk 1/2/3 to 1/2/4
  stack-port 1/2/1 1/2/3
stack unit 2
  stack-trunk 2/2/1 to 2/2/2
  stack-trunk 2/2/3 to 2/2/4
  stack-port 2/2/1 2/2/3
stack enable
stack mac xxxx.xxxx.xxxx
lag L30101 dynamic id 101
 ports ethernet 1/1/3 ethernet 1/1/5 ethernet 1/1/27 ethernet 1/1/29 ethernet 2/1/3 ethernet 2/1/5 ethernet 2/1/27 ethernet 2/1/29
 primary-port 1/1/3
 deploy
lag L30201 dynamic id 102
 ports ethernet 1/1/4 ethernet 1/1/6 ethernet 1/1/28 ethernet 1/1/30 ethernet 2/1/4 ethernet 2/1/6 ethernet 2/1/28 ethernet 2/1/30
 primary-port 1/1/4
 deploy
lag NODE01 static id 1
 ports ethernet 1/1/20 ethernet 1/1/44 ethernet 2/1/20 ethernet 2/1/44
 primary-port 1/1/20
 deploy
lag NODE02 static id 2
 ports ethernet 1/1/21 ethernet 1/1/45 ethernet 2/1/21 ethernet 2/1/45
 primary-port 1/1/21
 deploy
lag NODE03 static id 3
 ports ethernet 1/1/22 ethernet 1/1/46 ethernet 2/1/22 ethernet 2/1/46
 primary-port 1/1/22
 deploy
lag NODE04 static id 4
 ports ethernet 1/1/23 ethernet 1/1/47 ethernet 2/1/23 ethernet 2/1/47
 primary-port 1/1/23
 deploy
lag NODE05 static id 5
 ports ethernet 1/1/24 ethernet 1/1/48 ethernet 2/1/24 ethernet 2/1/48
 primary-port 1/1/24
 deploy
lag NODE06 static id 6
 ports ethernet 1/1/19 ethernet 1/1/43 ethernet 2/1/19 ethernet 2/1/43
 primary-port 1/1/19
 deploy
lag NODE07 static id 7
 ports ethernet 1/1/18 ethernet 1/1/42 ethernet 2/1/18 ethernet 2/1/42
 primary-port 1/1/18
 deploy
lag NODE08 static id 8
 ports ethernet 1/1/17 ethernet 1/1/41 ethernet 2/1/17 ethernet 2/1/41
 primary-port 1/1/17
 deploy
lag NODE09 static id 9
 ports ethernet 1/1/16 ethernet 1/1/40 ethernet 2/1/16 ethernet 2/1/40
 primary-port 1/1/16
 deploy
lag NODE10 static id 10
 ports ethernet 1/1/15 ethernet 1/1/39 ethernet 2/1/15 ethernet 2/1/39
 primary-port 1/1/15
 deploy
lag NODE11 static id 11
 ports ethernet 1/1/14 ethernet 1/1/38 ethernet 2/1/14 ethernet 2/1/38
 primary-port 1/1/14
 deploy
lag NODE12 static id 12
 ports ethernet 1/1/13 ethernet 1/1/37 ethernet 2/1/13 ethernet 2/1/37
 primary-port 1/1/13
 deploy
lag NODE13 static id 13
 ports ethernet 1/1/12 ethernet 1/1/36 ethernet 2/1/12 ethernet 2/1/36
 primary-port 1/1/12
 deploy
lag NODE14 static id 14
 ports ethernet 1/1/11 ethernet 1/1/35 ethernet 2/1/11 ethernet 2/1/35
 primary-port 1/1/11
 deploy
lag NODE15 static id 15
 ports ethernet 1/1/10 ethernet 1/1/34 ethernet 2/1/10 ethernet 2/1/34
 primary-port 1/1/10
 deploy
vlan 11 by port
 tagged ethe 1/1/1 to 1/1/48 ethe 2/1/1 to 2/1/48
 router-interface ve 11
vlan 4093 by port
 router-interface ve 4093
mstp scope all
mstp name abc
mstp revision 1
mstp instance 0 vlan 1
mstp instance 1 vlan 4093
mstp instance 2 vlan 11
mstp instance 3 vlan 12
mstp instance 4 vlan 13
mstp admin-pt2pt-mac ethe 1/1/3 to 1/1/4
mstp admin-edge-port ethe 1/1/1 to 1/1/2 ethe 1/1/7 to 1/1/26 ethe 1/1/31 to 1/1/33 ethe 2/1/1 to 2/1/2 ethe 2/1/7 to 2/1/9 ethe 2/1/25 to 2/1/26 ethe 2/1/31 to 2/1/33
mstp start
jumbo
enable telnet password .....
enable super-user-password .....
hostname L20101
ip dhcp-client disable
ip route 0.0.0.0/0 169.254.1.211
logging host 169.254.129.1
logging facility local4
snmp-server community ..... ro
snmp-server host 169.254.129.1 version v2c .....
ntp
 disable serve
 server 169.254.129.1
hitless-failover enable
interface ethernet 1/1/1
 dual-mode  11
interface ethernet 1/1/2
 dual-mode  11
interface ethernet 1/1/3
 dual-mode  11
interface ethernet 1/1/4
 dual-mode  11
interface ethernet 1/1/7
 dual-mode  11
interface ethernet 1/1/8
 dual-mode  11
interface ethernet 1/1/9
 dual-mode  11
interface ethernet 1/1/10
 dual-mode  11
interface ethernet 1/1/11
 dual-mode  11
interface ethernet 1/1/12
 dual-mode  11
interface ethernet 1/1/13
 dual-mode  11
interface ethernet 1/1/14
 dual-mode  11
interface ethernet 1/1/15
 dual-mode  11
interface ethernet 1/1/16
 dual-mode  11
interface ethernet 1/1/17
 dual-mode  11
interface ethernet 1/1/18
 dual-mode  11
interface ethernet 1/1/19
 dual-mode  11
interface ethernet 1/1/20
 dual-mode  11
interface ethernet 1/1/21
 dual-mode  11
interface ethernet 1/1/22
 dual-mode  11
interface ethernet 1/1/23
 dual-mode  11
interface ethernet 1/1/24
 dual-mode  11
interface ethernet 1/1/25
 dual-mode  11
interface ethernet 1/1/26
 dual-mode  11
interface ethernet 1/1/31
 dual-mode  11
interface ethernet 1/1/32
 dual-mode  11
interface ethernet 1/1/33
 dual-mode  11
interface ethernet 2/1/1
 dual-mode  11
interface ethernet 2/1/2
 dual-mode  11
interface ethernet 2/1/7
 dual-mode  11
interface ethernet 2/1/8
 dual-mode  11
interface ethernet 2/1/9
 dual-mode  11
interface ethernet 2/1/25
 dual-mode  11
interface ethernet 2/1/26
 dual-mode  11
interface ethernet 2/1/31
 dual-mode  11
interface ethernet 2/1/32
 dual-mode  11
interface ethernet 2/1/33
 dual-mode  11
interface ve 11
 ip address 169.254.1.201 255.255.255.0
interface ve 4093
 ip address 169.254.129.201 255.255.128.0
6> dm statistics
real_transition-transit-sw_reset-discards:
1-0-0-0(1/1/1) 0-0-0-0(1/1/2) 0-0-0-0(1/1/3) 0-0-0-0(1/1/4)
0-0-0-0(1/1/5) 0-0-0-0(1/1/6) 0-0-0-0(1/1/7) 1-0-0-0(1/1/8)
0-0-0-0(1/1/9) 1-0-0-0(1/1/10) 1-0-0-0(1/1/11) 0-0-0-0(1/1/12)
0-0-0-0(1/1/13) 0-0-0-0(1/1/14) 0-0-0-0(1/1/15) 0-0-0-0(1/1/16)
0-0-0-0(1/1/17) 0-0-0-0(1/1/18) 0-0-0-0(1/1/19) 1-0-0-0(1/1/20)
1-0-0-0(1/1/21) 0-0-0-0(1/1/22) 0-0-0-0(1/1/23) 0-0-0-0(1/1/24)
0-0-0-0(1/1/25) 0-0-0-0(1/1/26) 0-0-0-0(1/1/27) 0-0-0-0(1/1/28)
0-0-0-0(1/1/29) 0-0-0-0(1/1/30) 0-0-0-0(1/1/31) 0-0-0-0(1/1/32)
0-0-0-0(1/1/33) 1-0-0-0(1/1/34) 1-0-0-0(1/1/35) 0-0-0-0(1/1/36)
0-0-0-0(1/1/37) 0-0-0-0(1/1/38) 0-0-0-0(1/1/39) 0-0-0-0(1/1/40)
0-0-0-0(1/1/41) 0-0-0-0(1/1/42) 0-0-0-0(1/1/43) 1-0-0-0(1/1/44)
1-0-0-0(1/1/45) 0-0-0-0(1/1/46) 0-0-0-0(1/1/47) 0-0-0-0(1/1/48)
9-0-0-0(1/2/1) 8-0-0-0(1/2/2) 9-0-0-0(1/2/3) 4-0-0-0(1/2/4)
1-0-0-0(2/1/1) 3-0-0-0(2/1/2) 0-0-0-0(2/1/3) 0-0-0-0(2/1/4)
0-0-0-0(2/1/5) 0-0-0-0(2/1/6) 0-0-0-0(2/1/7) 1-0-0-0(2/1/8)
0-0-0-0(2/1/9) 1-0-0-0(2/1/10) 1-0-0-0(2/1/11) 0-0-0-0(2/1/12)
0-0-0-0(2/1/13) 0-0-0-0(2/1/14) 0-0-0-0(2/1/15) 0-0-0-0(2/1/16)
0-0-0-0(2/1/17) 0-0-0-0(2/1/18) 0-0-0-0(2/1/19) 1-0-0-0(2/1/20)
1-0-0-0(2/1/21) 0-0-0-0(2/1/22) 0-0-0-0(2/1/23) 0-0-0-0(2/1/24)
0-0-0-0(2/1/25) 0-0-0-0(2/1/26) 0-0-0-0(2/1/27) 0-0-0-0(2/1/28)
0-0-0-0(2/1/29) 0-0-0-0(2/1/30) 0-0-0-0(2/1/31) 0-0-0-0(2/1/32)
0-0-0-0(2/1/33) 1-0-0-0(2/1/34) 1-0-0-0(2/1/35) 0-0-0-0(2/1/36)
0-0-0-0(2/1/37) 0-0-0-0(2/1/38) 0-0-0-0(2/1/39) 0-0-0-0(2/1/40)
0-0-0-0(2/1/41) 0-0-0-0(2/1/42) 0-0-0-0(2/1/43) 1-0-0-0(2/1/44)
1-0-0-0(2/1/45) 0-0-0-0(2/1/46) 0-0-0-0(2/1/47) 0-0-0-0(2/1/48)
13-0-0-0(2/2/1) 13-0-0-0(2/2/2) 7-0-0-0(2/2/3) 25-0-0-0(2/2/4)
What is TAC case? I don't have any idea of it, and how can we open it?
Hi Ben,
Did you find any clue regarding above problem with provided information ?
