02-29-2024 01:03 AM
My ICX7150-C12P has been working flawlessly, and powering my CCTV around my premises. However, today, my cameras went offline as well as my APs, and my serial connected to the switch populates with Info: Device Key or Cert file is not available over and over, every 2 seconds. I tried reloading and using the webportal, to no avail. Please advise! Thank you
02-29-2024 01:51 AM - edited 02-29-2024 02:35 AM
Hi imcobra,
Thank you for posting you query !!!
I understand that ICX7150-C12P is not working and you are geeting error Info: Device Key or Cert file is not available in
every 2 second.
I have a question for you here :
Are you able to run any commands while on console? Or this error is constant making it really difficult (or impossible) to type any commands on it?
If you are able to type any commands I would appreciate the following
show version
show flash
dm verify-device-certs
Mostly in this kind of error we would do RMA, While typing dm verify-device-certs if you get the below error:
Verifying TPM files ...
Failed: Check TCSD_PS Files
Please log a ticket with the below link so that we will help you to process RMA
Note: Please confirm us if you are from Lennar homes
I hope this information helps you
Please feel free to leave us a message if any concerns
02-29-2024 08:58 AM
I will try the commands you mentioned when I return to the property this afternoon. When I was trying to type on the console, it was a fight to get a command out before it was repopulated with the Device Key or the Cert file was not available over and over.
I know I'm on version: UNIT 1: compiled on Apr 11 2023 at 00:06:30 labeled as SPS08095j
(31457280 bytes) from Primary SPS08095j.bin (UFI)
SW: Version 08.0.95jT211
Compressed Primary Boot Code size = 786944, Version:10.1.26T225 (mnz10126)
Compiled on Tue Nov 29 12:43:26 2022
I will get you the information from the other commands later today. Thank you
02-29-2024 09:07 AM - edited 02-29-2024 09:09 AM
Hi imcobra,
Thank you for the update.
It looks like we need to replace the Switch.
02-29-2024 10:59 AM
Here is the info from the commands you requested:
HW: Stackable ICX7150-C12-POE
UNIT 1: SL 1: ICX7150-C12-2X10GR POE 12-port Management Module
Serial #:#########
Current License: 2X10GR
8 MB boot flash memory
2 GB code flash memory
1 GB DRAM
STACKID 1 system uptime is 10 hour(s) 8 minute(s) 5 second(s)
The system started at 00:06:39 GMT+00 Tue Apr 11 2023
Stack unit 1:
Compressed Pri Code size = 31457280, Version:08.0.95jT211 (SPS08095j.bin)
Compressed Sec Code size = 31457280, Version:08.0.95jT211 (SPS08095j.bin)
Compressed Pri Boot Code size = 786944, Version:10.1.26T225 (mnz10126)
Compressed Sec Boot Code size = 786944, Version:10.1.26T225 (mnz10126)
Code Flash Free Space = 1069690880
a
Commencing sanity check for device certs ...
The switch was from my former Lennar home. How do I proceed with replacement? Thank you
