Icx7150-c12p will no power up
scott_harter
Switch will not power up. No LEDs no humming. Nothing. Is there any way to bring this back to life? Or is it just dead?
Thx,
Scott
4 REPLIES 4
israr_ahmed_93c
if its not getting power on . please check power cable , plug etc. check its warranty period. if its under warranty please rma device. there is no more obtion to try in my openion
scott_harter
Thanks, thats what I figured.  It's under warranty still, so I opened a ticket.  I don't know much about switches but I am well versed in other electronics.  I assume the fault lies with the power supply.  I also assume it will be replaced under warranty.  Unless something of interest comes from this, I most likely will not respond to this thread.  Thanks again for your help.
yadiel_tasis
did any lights blink
jonmichael_gold
Same just happened to mine
