ICX7150 no output show inline power
Hi All
We have an ICX7150-24P-4X1G POE 24-port, with  10 R510 AP's.
All the AP's are down but switch is up leading to me a POE issue.
Switch has been rebooted with no change, However there is no output to the sh power inline command.
would the POE module failing cause there to be no output?
5 REPLIES 5
simon_pollard
Contributor II
As Vincent suggested try reloading the PoE firmware. I would suggest upgrading to 8.0.70d and the PoE upgrade will be done automatically.
If that does not help you should open a TAC case as the switch will probably need to be RMA'd.
