11-04-2025 05:26 PM
I believe that currently, ICX7150-24P and ICX7150-48PF support PTP transparent clock, ICX7150-48P does not.
1. Will PTP transparent clock capability be added to ICX7150-48P prior to end of software maintenance?
2. With current FastIron 08.0.95s, can PTP transparent clock be used on an ICX7150-24P that is in the same stack as an ICX7150-48P?
11-05-2025 02:46 AM
Hi aeg,
For now, PTP is only supported on the ICX7150-24 and ICX7150-C12P in 08.0.95. Support added for the ICX7150-24P, ICX7150-48PF, and ICX7150-C10ZP in 08.0.95C.
Mayank
11-05-2025 03:30 AM
Thank you for your reply. Yes, I have seen the releases and supported platforms table in the FastIron Management Configuration Guide. Will PTP transparent clock capability be added to ICX7150-48P prior to end of software maintenance? With current FastIron 08.0.95s, can PTP transparent clock be used on an ICX7150-24P that is in the same stack as an ICX7150-48P?
01-14-2026 11:49 PM
It would be nice to get an answer about the possibility of future PTP transparent clock capability on the ICX7150-48P from someone who has insight into future software development plans. (You can also interpret this as a signal that there is interest in this capability.)
It would also be nice to get an answer about whether PTP transparent clock be used on an ICX7150-24P that is in the same stack as an ICX7150-48P, from someone with knowledge about how the products operate. I don't have a support contract, so I can't open a ticket to ask this.
Of course, I understand that the support available through the community forum will not have the speed and quality available with a support contract. But it's disappointing that I haven't received an answer here that is responsive to the questions I asked.
