I have been configuring our ICX 7150 switch as the DHCP Server to our vSZ using option 43 and option 60. This works perfect for our Ruckus APs as they can now automatically register to the vSZ once we plug them into the ICX switch.
However the issue I am having is that it does not work the same for any Ruckus ICX switches I want to add into the same vSZ. When I plug another ICX switch into the main DHCP server ICX switch, it just doesn't seem to get a lease and connect to the vSZ.
When creating the DHCP pool and adding the
vendor-class ascii "Ruckus CPE" command, it states it is for the Ruckus APs in the guides I have read.
Does anyone know if there is a different Vendor Class ID for Ruckus ICX switches?
Things to note:
- vSZ firmware is on 5.0.0.0.675 - this is gives me the Switches menu on the left nav bar in my vSZ
- Factory reset Ruckus ICX firmware is on 8.0.80
