06-18-2021 02:02 PM
Connection no response, please try again later. (last command: copy flash flash secondary)
06-18-2021 02:18 PM
Hi Dominik,
Hope you are doing Great!!!
This is a command to copy image from Primary to Secondary flash.
Can you please get me output of "show flash", "show version" and "show run | i boot"
Also please tell me what version you are upgrading from and to?
Hashim
06-18-2021 02:26 PM
Hi, I am trying to upgrade the switch trough vsz on remote location, so I cannot run that commands.
I can though send you last backup config and version I am trying to upgrade to is 08059d.
Last backup:
ver 08.0.90jT213
stack unit 1
module 1 icx7150-48p-poe-port-management-module
module 2 icx7150-2-copper-port-2g-module
module 3 icx7150-4-sfp-plus-port-40g-module
stack-port 1/3/1
stack-port 1/3/3
enable aaa console
ip dns server-address 8.8.8.8 8.8.4.4
ip route 0.0.0.0/0 192.168.1.1 distance 254 dynamic
username super password 8 $1$KHaRHOxv$igh8FhuiC4TfWdUw/ioVS1
web-management https
sz registrar 34.90.89.117
sz active-list 34.90.89.117 10.164.0.3
interface ethernet 1/1/1
ip address 192.168.1.3 255.255.255.0 dynamic
interface ethernet 1/3/1
speed-duplex 1000-full
interface ethernet 1/3/2
interface ethernet 1/3/3
interface ethernet 1/3/4
en
06-18-2021 03:03 PM
Thanks Dominik,
Seems like the failure is when the file is being copied from primary to secondary flash.
From your config you are booting from primary which is the default.
Steps to access switch console:
The SmartZone administrator must complete the following steps to access a CLI session.
Then you should be able to run the commands.
The failure is after the image is copied to primary the next step is copy of image to secondary from primary, which is where it is failing.
Hashim
06-18-2021 03:07 PM
I do not have that CLI command
