ICX Brocade switch forwarding LLDP packet
alex_shalima
Contributor
I'm working a hybrid-vendor network. Here is how it is all connected:
Cisco 4500 -> Brocade 7450 -> Brocade 7250 -> HP 2920
Situation:
The funny thing is that on the uplink port of the HP switch (port 24) I'm seeing the Cisco 4500 LLDP info. By standard, it shouldn't really be there. It's 2 hops too far to show that data.
  Local Port   : 24
  ChassisType  : mac-address
  ChassisId    : 78 a6 e1 09 cb 58
  PortType     : mac-address
  PortId       : 78 a6 e1 09 cb 8f
  SysName      : SW-MDF-3-02
  System Descr :
  PortDescr    : 10GigabitEthernet1/2/7
  Pvid         : 7
  System Capabilities Supported  : bridge
  System Capabilities Enabled    : bridge
  Remote Management Address
     Type    : ipv4
     Address : 10.7.254.11
  Local Port   : 24
  ChassisType  : local
  ChassisId    : HRH-4500X-VSS
  PortType     : local
  PortId       : TenGigabitEthernet1/16
  SysName      :
  System Descr : Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Swi...
  PortDescr    :
  Pvid         :
  System Capabilities Supported  : bridge, router
  System Capabilities Enabled    : bridge, router
     Type    : ipv4
     Address : 172.17.10.1
My question is: does Brocade implement any sort of LLDP packet forward mechanism? If it does, can it be limited to only 1 switch?
5 REPLIES 5
Hi Mitchell and Ben.
Thanks for your replies.
Enabling CDP on both Brocade switches has solved it.
Cheers!
****SOLUTION****
Enable CDP on Brocade
