ICX 7450 Failed Firmware? how can to recover from failed firmware, without using serial/console
Imeguras
So my icx 7450 had some really old firmware(2017) i think and i tried to jump to a higher version (8080f) unfortunately now the switch seems to be stuck at bootloader as it makes a whole lot of noise and never boots.
As of right now i've always telnet'ed my way into it throught the out of band port since i've yet to figure out how does the usb mini type b serial port works(i've tried rigging something with a TTL and some spare connectors i oddly had, for an old keyboard, to see if i could read the UART signal but no shot)
How can i fix it ?
1 ACCEPTED SOLUTION
Imeguras
Fixed, what i did wrong was installing a way more up to date image and i didnt update the bootloader
3 REPLIES 3
Imeguras
I bought a converter for the serial port from here https://www.amazon.es/-/pt/gp/product/B0C9C7NR8F?smid=&psc=1
still no data
Imeguras
After nearly reverse engineering the adapter and the transceiver I got this
(some characters might be missing due to poor connection as i had to use jumper wires and an oscilloscope... More money i guess)
BroaeBootloader: 1010T1 Dc1 015 - 13:10:57)
Validate Shmoo arameters stored in flash ..... OK
RsoigSmoo parameesfo flash .....
ICX7450-48 Copper (POE), PVT4 . O
SYS CPLD VER: 0x10, ReleasedVr: 0
bodelay: === stop at bot monito  0
.........................................................Wrong Image Format for bootm comma
nd
RROR: can't get kernel image!
ol not boot fromsecondary, no aid image; trig to boot from primary
BOIGiaefo Piay
..........................................................................................W
ogIage Fora frbotm ommand
RROR: ca't get kernel image!
ICX7450-Boot> ^C
Imeguras
