ICX 7150 router/switch
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
10-13-2022 02:22 AM
hi,
is there any possibility to get my ICX 7150 back into switch mode ? I had some problems after updating the switch and i just made a copy from secondary to primary boot and at that point i didn't realize that the second boot option is actually a router.
Stack unit 1:
Compressed Pri Code size = 32539748, Version:08.0.90dT213 (SPR08090d.bin)
Compressed Sec Code size = 32539748, Version:08.0.90dT213 (SPR08090d.bin)
Compressed Pri Boot Code size = 786944, Version:10.1.15T225 (mnz10115)
Compressed Sec Boot Code size = 786944, Version:10.1.15T225 (mnz10115)
Code Flash Free Space = 1098846208
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-13-2022 05:50 AM - edited 10-13-2022 05:58 AM
Hi @Ana_10
Hope you are doing well !
In order to resolve or fix this you must install or upgrade the desired image on the switch partition.
What you can do if the switch is running the routing code is assign an IP to an interface or to the management interface in order connect your PC to, then assign an IP to the interface on the PC with the same range that you have done on the switch and do the upgrade via TFTP or SCP server to the desired image which is SPS8090dufi.bin.
Configure IP address:
TFTP example
Copy tftp flash ( server IP ) ( image root folder ) primary
Quick Guide:https://support.purdi.com/hc/en-gb/articles/360016568231-Ruckus-ICX-Firmware-Upgrade-Guide-
You can also skip the Connectivity process by using a USB/flash drive which has to be in 32 FAT format, here all you must do is connect the USB to PC, move the desired image to the USB without any folder to avoid root folders problem on the USB (just the image), then connect the USB to the Switch and verify that the usb can be read by the switch using the following commands
Mount disk0: Check if the usb is present or mounts the filesystem of the external USB.
Show files disk0: Let us know the files that are on the USB
Example of the upgrade:
Router#copy disk0 flash SPS08090daufi.bin primary
Quick guide:
https://support.n4l.co.nz/s/article/Ruckus-Switch-Firmware-Upgrade-Using-USB
I hope this help you
Best regards
Fernando Vasquez
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-13-2022 05:54 AM
Yes, you could surely re-copy switching code if you would like. You would need to download switch code (denoted by SPS in the filename). Code is available on our support portal. The procedure to upgrade the code would look like this:
copy tftp flash <ip address of TFTP server> <UFI-code-image> <primary/secondary>
Example
copy tftp flash 192.168.1.250 SPS08095hufi.bin primary
With that said, you could also stay on routing code. Your ICX can still switch normally. The only difference is that your IP addressing will change and you will need to address at the interface/VE/mgmt port level. Hope that helps!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-13-2022 11:01 PM
Before i posted this i tried updating the ICX using the manifest command/file and it update but it was a router then i realized i had to put at the end of the command router/switch in my case switch.
Thank you 🙂
