09-09-2022 09:54 AM
Can any one tell me why 08.0.95g is the recommended firmware when there is 09.0.10c?
I have all my 7250's on 09.0.10c and when I contracted support for an issue they said that I need to go back to 08.0.95g.
Confused
09-09-2022 01:24 PM
Hey @network_adminis
I certainly understand the frustration there. Moving back from 9.x to 8095 is also not a trivial item as syntax has changed between the two. Upgrading is seamless, but downgrading is not. You will want to make sure you either have your 8095 config handy (if you had one) or be sure to do the new config via console. As for the code, you can always check our product page to see our recommendation. Please see the attached screenshot:
I would always start here and then change code if required. A newer patch in the same codestream (ex. 8095h) is also generally a safe bet.
