ICX 7150 48P - VoIP Phones
giorgio_sacchi
Good morning,
I have 2 ICx 7150 switches in stack.
This is my config
Current configuration:
ver 08.0.80dT211
stack unit 1
  module 1 icx7150-48p-poe-port-management-module
  module 2 icx7150-2-copper-port-2g-module
  module 3 icx7150-4-sfp-plus-port-40g-module
  stack-port 1/3/1 1/3/3
stack unit 2
  stack-port 2/3/1 2/3/3
stack enable
stack mac d4c1.9e26.4c9b
stack suggested-id 1
vlan 100 name XXX by port
 tagged ethe 1/1/25 ethe 1/1/37 to 1/1/48
vlan 105 name XXX_VOIP by port
 tagged ethe 1/1/48
 untagged ethe 1/1/25
vlan 125 name XXX_MANAGEMENT by port
 tagged ethe 1/1/48
 untagged ethe 1/1/37 to 1/1/46
aaa authentication enable default local
aaa authentication login privilege-mode
enable super-user-password .....
hostname XXX_SW01_LAB
ip address 172.31.253.241 255.255.255.0
ip default-gateway 172.31.253.254
username admin password .....
cdp run
fdp run
clock timezone gmt GMT+01
hitless-failover enable
sz active-list 192.168.100.192 83.216.184.111
lldp run
end
I have 3 VLANs
100 - Date
105 - VoIP
125 - MGMT
On the 1/1/25 port (Vlan 105) I attached a VoIP phone (SNOM) that correctly takes an IP
In fact, through the "sh lldp neighbors" command I see it
Image_ images_messages_5f91c3f9135b77e247904462_dc74e391e641b02cbe23c38c8a862563_RackMultipart20190110110398g63-fa6f3061-5761-4880-9704-6c2d1c494353-888630229.JPG1547116993
How can I make the other phone's port release an IP of the VLAN 100 to be able to connect a PC (The Dual-Mode command is disabled)?
Thank you
4 REPLIES 4
