ICX 7150 48P - VoIP Phones
giorgio_sacchi
Good morning,
I have 2 ICx 7150 switches in stack.
This is my config
Current configuration:
ver 08.0.80dT211
stack unit 1
  module 1 icx7150-48p-poe-port-management-module
  module 2 icx7150-2-copper-port-2g-module
  module 3 icx7150-4-sfp-plus-port-40g-module
  stack-port 1/3/1 1/3/3
stack unit 2
  stack-port 2/3/1 2/3/3
stack enable
stack mac d4c1.9e26.4c9b
stack suggested-id 1
vlan 100 name XXX by port
 tagged ethe 1/1/25 ethe 1/1/37 to 1/1/48
vlan 105 name XXX_VOIP by port
 tagged ethe 1/1/48
 untagged ethe 1/1/25
vlan 125 name XXX_MANAGEMENT by port
 tagged ethe 1/1/48
 untagged ethe 1/1/37 to 1/1/46
aaa authentication enable default local
aaa authentication login privilege-mode
enable super-user-password .....
hostname XXX_SW01_LAB
ip address 172.31.253.241 255.255.255.0
ip default-gateway 172.31.253.254
username admin password .....
cdp run
fdp run
clock timezone gmt GMT+01
hitless-failover enable
sz active-list 192.168.100.192 83.216.184.111
lldp run
end
I have 3 VLANs
100 - Date
105 - VoIP
125 - MGMT
On the 1/1/25 port (Vlan 105) I attached a VoIP phone (SNOM) that correctly takes an IP
In fact, through the "sh lldp neighbors" command I see it
Image_ images_messages_5f91c3f9135b77e247904462_dc74e391e641b02cbe23c38c8a862563_RackMultipart20190110110398g63-fa6f3061-5761-4880-9704-6c2d1c494353-888630229.JPG1547116993
How can I make the other phone's port release an IP of the VLAN 100 to be able to connect a PC (The Dual-Mode command is disabled)?
Thank you
4 REPLIES 4
paul_mcguire_20
Contributor
You have to Tag each port for the voice vlan and untag the ports on the data vlan. Be sure to tag first the. Untag the data port second or it will not allow the command.
Be sure any uplinks have the vlans tagged as well.
Config t
Vlan 105
Tag Ethernet 1/1/1 to 48
Vlan 100
Untag e 1/1/1 to 48
On each port do
Config t
Int e 1/1/1 to 48
trust dscp
voice vlan 105
The next step is outside the switch. Depending on your voip equipment it may differ. I have shoretel and it requires a dhcp option 156 to be setup that specifies the vlan to hop to.
Hope this helps
PJM
netwizz
Contributor III
Paul is right on with the reply.  In Paul's reply VLAN 105 is the Voice VLAN and 100 is the data VLAN.
You might also want to add an LLDP Media Endpoint Detection profile LLDP-MED:
On a Cisco switch, you would add it under the interface as a Voice VLAN which announces the VLAN.  Otherwise the equivalent would be making a trunk port then adding the data vlan as a native VLAN, which is exactly what Paul is having you do on the Brocade/Ruckus 7150 with the Tagged and Untagged Terminology where Untagged = Access port and Tagged = Trunk Port.  Dual-Mode is essentially a Native VLAN, but now you  tag an interface in as many VLANs as you want and untag it to only one VLAN for its native VLAN, so they have depreciated the use of the dual-mode keyword.
What I want to add to the answer,
You can announce the Voice VLAN to the phones via LLDP, too:
lldp med network-policy application voice tagged vlan 105 priority 5 dscp 46 ports ethe 1/1/1 to 1/1/48
chris_thomas_68
This is what I do, and works nicely
interface ethernet 1/1/1 to 1/1/48
 voice-vlan 105
 trust dscp
lldp tagged-packets process
lldp med network-policy application voice tagged vlan 105 priority 5 dscp 46 ports all
lldp med network-policy application voice-signaling tagged vlan 105 priority 4 dscp 42 ports all
giorgio_sacchi
I followed your advice and confirm that it now works perfectly.
I only changed the interface from 1/1/25 to 1/1/29 but now I will define a range of IP addresses.
I enclose my config in case it can then be useful to someone else.
Thank you
ver 08.0.80dT211
stack unit 1
stack unit 2
stack enable
 tagged ethe 1/1/48
 untagged ethe 1/1/29
 tagged ethe 1/1/29 ethe 1/1/48
 tagged ethe 1/1/48
cdp run
fdp run
clock timezone europe CET
ntp
 server 172.31.253.254 burst
interface ethernet 1/1/29
 voice-vlan 105
 trust dscp
lldp med network-policy application voice tagged vlan 105 priority 5 dscp 46 por        ts ethe 1/1/1 to 1/1/48 ethe 1/2/1 to 1/2/2 ethe 1/3/2 ethe 1/3/4 ethe 2/1/1 to        2/1/48 ethe 2/2/1 to 2/2/2 ethe 2/3/2 ethe 2/3/4
lldp med network-policy application voice-signaling tagged vlan 105 priority 5 d        scp 46 ports ethe 1/1/1 to 1/1/48 ethe 1/2/1 to 1/2/2 ethe 1/3/2 ethe 1/3/4 ethe        2/1/1 to 2/1/48 ethe 2/2/1 to 2/2/2 ethe 2/3/2 ethe 2/3/4
lldp run
end
