01-11-2026 03:21 PM
'Ruckus is great on AP firmware. Why can I find a complete download for the Ruckus ICX 6430-24P
01-11-2026 08:54 PM
I installed 08095s again and as expected it stops in the single used init shell.
I showed chatgpt the files in the mounted /fast_iron directory and it reported on what is missing.
That find output is the final smoking gun. It tells us everything, with zero ambiguity.
Your output:
There is no:
That means:
❌ No FastIron userland
❌ No CLI
❌ No init scripts
❌ No services
❌ No networking stack
BusyBox is not a failure — it’s the fallback shell when FastIron cannot start.
On a working unit, you would see something like:
The absence of /bin proves conclusively:
No monolithic / factory image has ever been installed on this flash.
You successfully flashed images
The kernel boots
Flash is writable
/fast_iron mounts
But the filesystem contains only scaffolding
That exact layout is what you get from:
bootstrap images
update images
reduced images
Never from a factory (m) image.
At this point, there is no command you can run, no file you can copy, no ZIP you can download that will suddenly populate /fast_iron/bin.
Only one thing does that:
And you have conclusively shown it is not available in public downloads.
Hardware: ✅ good
Flash: ✅ good
Bootloader: ✅ good
Recovery procedure: ✅ correct
Vendor policy: ❌ blocks you
You did not brick the switch.
Ruckus policy did.
Only these two actions can change the outcome:
Donor ICX7450 → extract factory image
Ruckus TAC / partner → request factory image
Anything else is guaranteed churn.
You followed the boot chain correctly.
You validated every assumption empirically.
You reached the same conclusion Ruckus TAC would reach in 5 minutes.
The system is in permanent “pre-install” state.
If you want, I can help you with exactly one of these, cleanly and efficiently:
drafting a minimal TAC request that gets the file without back-and-forth
writing donor-extraction commands so you don’t brick the donor
deciding how to dispose of or disclose the unit honestly
Just tell me which one you want to do.
01-11-2026 08:59 PM
I installed the image with
image_name=08095s/ruckus_icx6430/ruckus_icx6430_08030k/ICX64xx/Images/ICX64S08030k.bin
with update_primary cmd.
01-11-2026 09:14 PM
I looked over the upgrade instructions and its going over the TFTP approach that I am using but it remains as an update solution and Im starting with switches that have be cleaned and I think I need to do a full install.
It's a long doc and I may have missed something. So I have chatgpt read it as well. It continues to think that this update procedure isn't going to un-brick my switches.
Thanks for the link — you just shared a FastIron 08.0.30 upgrade guide PDF. That’s useful for overall understanding of how switch upgrades work, but it does not contain the factory/monolithic image (ICX64S…m.bin) you need to recover your switch.
Here’s the key distinction:
This document (FastIron 08.0.30 Upgrade Guide):
✅ Explains how to upgrade from one version to another
✅ Shows the supported procedures using u images
✅ Has examples of using TFTP, Bootloader, CLI commands
✅ Is great for normal switch maintenance
But it does not provide:
❌ The monolithic firmware image
❌ Any URLs to factory blobs
❌ A way to install an OS on a wiped switch
So reading that guide won’t fix the fact your switch currently boots only to BusyBox.
Your switch is in a state where:
Flash is essentially blank
Only bootloader and minimal kernel are present
/fast_iron contains no userland
ICX CLI doesn’t exist on the box
No CLI will ever appear without a factory image
The upgrade guide assumes:
The switch already has a complete FastIron install
That’s exactly what your switch doesn’t have, which is why referencing an upgrade guide won’t fix your situation.
What you actually need is a file such as:
or equivalently named monolithic / factory images for the ICX64xx platform.
Those contain:
✔ Full OS (FastIron userland)
✔ CLI binaries
✔ Init scripts
✔ Networking stack
✔ All switch services
Without one of these in flash, the switch always drops to BusyBox.
Upgrade guides never include huge firmware blobs. They describe how to upgrade, not provide the firmware.
That’s why:
📄 You saw an upgrade guide
❌ You did not see factory images anywhere
✔ Because those are part of the binary firmware packages — not documentation
But as we discussed earlier, Ruckus no longer publicly publishes the factory images in their zip bundles.
You have a Brocade/Ruckus ICX7450 that boots only to BusyBox.
Public downloads contain only update images (u / k) and not m.
Upgrade guides assume a working OS — they don’t apply here.
You need a monolithic factory image, which is not in the public download you have.
This is a policy/packaging issue with the vendor — not a user error.
Here are the paths that genuinely address the underlying problem:
If you (or a colleague) have any working ICX7450:
That file will restore your switch.
This is the most practical recovery path people use in labs.
Open a support case and request:
“ICX64xx / ICX7450 monolithic/factory image — flash erased, only BusyBox boot.”
Under support/contract, Ruckus will provide the appropriate m.bin.
In some community forums or old mirrors, the monolithic image may still exist.
But these are unofficial, have varying availability, and I can help you verify a file before you use it if you find one.
If you want, I can help you with precise wording to ask Ruckus TAC so they understand your exact recovery situation and provide the correct file without back-and-forth.
Or if you find a potential monolithic image on a mirror, paste its name or link here and I’ll confirm whether it’s the right one.
Just tell me which direction you want to go:
✔ Get the exact TAC request text
OR
✔ I’ll help you search specific community mirrors for the factory image
Either one will move you forward — just pick one.
01-14-2026 05:47 AM
Here is the full recovery from bootmon if that is where you are stuck:
setenv ipaddr <device IP address> - set ip address
setenv netmask <255.255.255.0> - set subnet mask
setenv serverip <xxx.xxx.xxx.xxx> - set tftp server address
setenv gatewayip <xxx.xxx.xxx.xxx> - set gateway address
printenv
- Try to ping your TFTP server. If you cannot ping, check your connections. Once ping is successful, enter these commands:
setenv uboot <boot-code-bin> (change boot code image as needed)
setenv image_name <OS-image-bin> (change OS image as needed)
saveenv
tftpboot
Once booted, you will need to do a normal tftp copy from the fastiron OS to save it in flash. (tftpboot is one time; temporary)
01-15-2026 06:11 PM
Im not having any problems installing. The problem is that the installed bits are incomplete.
I've done the install proceedure with about a dozen on the available images.
Perhaps The //fast_iron bits seem to be incomplete:
/ # find /fast_iron -print
/fast_iron
/fast_iron/sys
/fast_iron/sys/cvpersistent
/fast_iron/sys/persistent
/fast_iron/sys/cvpersistent.bkup
/fast_iron/sys/meta_data.bin
/fast_iron/sys/persistent.bkup
/fast_iron/sys/system
/fast_iron/sys/system.bkup
/fast_iron/logs
/fast_iron/logs/script.log
/fast_iron/logs/bootmsg
/fast_iron/cores
/fast_iron/$$ssh8rsahost.key
/fast_iron/poe-fw
CTRL-A Z for help | 9600 8N1 | NOR | Minicom 2.9 | VT102 | Offline | ttyUSB1
The /fast_iron/logs/script.log shows:
/dev/mtd3 partition's magic Number = 6533
JFFS2 magic number found.
Config partition mounted.
FIPS reset is enable.
Removing startup config & backup
Removing stacking.boot
Removing SSL_CERT_FILE
Removing SSH_RSA_HOSTKEY_FILE
Removing SSH_DSA_HOSTKEY_FILE
Inserting the module with watchdog disabled.
bunzip2: /bin/core.sh.bz2: No such file or directory <<<<<< BUG
mkdir: can't create directory '/dev/net': File exists
mknod: /dev/net/tun: File exists
Creating the first Tap interface
Set 'tap0' persistent and owned by uid 0
route: resolving br0
ERROR: Failure in gw add
The # ls /bin/core directory is EMPTY:
ls: /bin/core: No such file or directory
Also the /net directory is missing.
