06-12-2024 04:48 AM - edited 06-12-2024 05:07 AM
We have a couple of these deployed supporting the R760 which is uplinked at 2.5Gbps. Currently all APs are reporting that they are only connected to a 802.3at capable switch. The datasheet for the ICX 7150 states that the 7150-C10ZP has 4x 802.3bt ready ports but I cant find any documents that get into the specifics for the 7150-C10ZP.
Which ports support 802.3bt and how do I enable it?
Power Capacity: Total is 240000 mWatts. Current Free is 92340 mWatts.
Power Allocations: Requests Honored 10 times
1/1/1 On On 11400 29532 2P-IEEE Class 4 3 n/a
1/1/2 On On 11600 29532 2P-IEEE Class 4 3 n/a
1/1/3 On On 11000 29532 2P-IEEE Class 4 3 n/a
1/1/4 On On 11400 29532 2P-IEEE Class 4 3 n/a
1/1/5 On On 12600 29532 2P-IEEE Class 4 3 n/a
1/1/6 On Off 0 0 n/a n/a 3 n/a
1/1/7 On Off 0 0 n/a n/a 3 n/a
1/1/8 On Off 0 0 n/a n/a 3 n/a
1/2/1 On Off 0 0 n/a n/a 3 n/a
1/2/2 On Off 0 0 n/a n/a 3 n/a
Total 58000 147660
When I try to set the inline power by class on any port, I get the following. It's as if the switch doesn't support going past 802.3at power.
config-if-e1000-1/1/1)#inline power power-by-class 5
PoE Error: Please specify the class number in the range 1..4
