How to Fix Error 0x80004002 “No such interface supported” when I try to set up ZD1200?
peter_w_9h7tcet
Contributor II
Image_ images_messages_5f91c3f5135b77e2478fad21_243e2f23eb245eed1dee88336871c5f0_RackMultipart20200508804221odr-7f6010cc-8754-4388-806c-8c518f04cd52-1683875310.JPG1588954283
Trying to run through quick set up guide on Windows 10 and have this problem.  Have installed Java.  Not sure why I can proceed.  Would like to use this computer as admin but will switch to another if I must.
2 REPLIES 2
peter_w_9h7tcet
Contributor II
Tried on another PC which took me to the ZD sign in page.  Admin name "admin" Password "admin" doesn't work!  Does this mean that it's been changed by someone?  I bought this mail order but it was new in the box.  Is there any fix for this or do I need to return the unit and face mega delays in fixing my network.
peter_w_9h7tcet
Contributor II
Please ignore - I did a factory reset which solved the problem.  Was sold this item as new but it clearly has been used before and someone had password protected it.
