Showing results forย
Search instead forย
Did you mean:ย
How do I stack two ICX7150 switches?
Hello everyone,
I'm a novice at best, really a simple DIY'er. Amazon installed a Ruckus ICX7150 switch in my smart panel and I have an acces point upstairs and another downstairs. Since there's already a cable running from the panel, up through the attic, and to the access point, I would like to use that cable. My plan is to remove it from the access point and route it to a switch another switch. I would then run another cable from that switch and to the access point and then I would be able to run more cables as needed for other rooms upstairs. I have no wired lines and would like to have a few.
Is this possible? If so, what kind of cable do I need to connect the switches and to what ports? Also, does the second switch need to be the same brand and type as the Ruckus ICX7150 downstairs?
1 REPLY 1
