Igor,
Thanks, the diagram is a little off, as it was one I did as I was still building. DHCP is on a Windows server off second switch, on Vlan 1. Here is the show run for second ICX7150:
Current configuration:
ver 08.0.61aT213
stack unit 1
module 1 icx7150-24p-poe-port-management-module
module 2 icx7150-2-copper-port-2g-module
module 3 icx7150-4-sfp-plus-port-40g-module
global-stp
lag ToMain dynamic id 1
ports ethe 1/1/1 to 1/1/2
router-interface ve 1
spanning-tree
vlan 2 by port
tagged ethe 1/1/16 to 1/1/24 lag 1
router-interface ve 2
spanning-tree
vlan 3 by port
router-interface ve 3
spanning-tree
vlan 10 name Guest by port
untagged ethe 1/1/15
spanning-tree
enable telnet authentication
enable aaa console
hostname "Brocade Annex-240"
ip dns domain-list DOMAIN.MY
ip dns server-address 10.56.0.6 10.56.0.8
ip route 0.0.0.0/0 10.56.0.1
ip route 10.56.2.0/24 ve 2
ip route 10.56.2.0/24 0.0.0.0
ip route 10.56.3.0/24 ve 3
ip route 10.56.3.0/24 0.0.0.0
username Admin password .....
password-change any
snmp-server contact Tom Lebel
snmp-server location Annex Computer Room
clock timezone gmt GMT-05
web-management https
interface ethernet 1/1/16
dual-mode
inline power
interface ethernet 1/1/17
dual-mode
inline power
interface ethernet 1/1/18
dual-mode
inline power
interface ethernet 1/1/19
dual-mode
inline power
interface ethernet 1/1/20
dual-mode
inline power
interface ethernet 1/1/21
dual-mode
inline power
interface ethernet 1/1/22
dual-mode
inline power
interface ethernet 1/1/23
dual-mode
inline power
interface ethernet 1/1/24
dual-mode
interface ethernet 1/3/1
speed-duplex 1000-full
interface ethernet 1/3/2
interface ethernet 1/3/3
interface ethernet 1/3/4
interface lag 1
dual-mode
interface ve 1
ip address 10.56.0.240 255.255.254.0
interface ve 2
ip address 10.56.2.240 255.255.255.0
interface ve 3
ip address 10.56.3.240 255.255.255.0
end
TT
