Showing results forย
Search instead forย
Did you mean:ย
Help with upgrading firmware.
I am looking into upgrading firmware on our icx 7150 switches and I wanted to verify upgrade options. We currently have a number of switches running 08.0.80caT211 and some that are running 08.0.90bT213. The older version is a non router firmware and the others are router firmware. I would like to have all switches on the 08.0.90bT213 firmware. My main question is if I upgrade a non router switch to router capable firmware will they go offline until I change the ip information, or will they convert the current information to match new configuration options? Will I have to use a console connection to manually change the settings to the proper default gateway and add a routable virtual interface.
6 REPLIES 6
You an also upgrade the existing 08090b to 08090d with the same command for consistency...
ftp flash x.x.x.x SPR08090bufi.bin primary
I would also do a "write memory" or "wr mem" before the restart just incase the vendor did not save all configurations for some reason.
You also want to do a "sh clock" to ensure the time is proper.  For example right now I get:
08:09:46.999 Eastern Wed Oct 02 2019
If the time is wrong, check your NTP and time-zone settings via "show run" and "sh ntp associations"
My commands are:
clock summer-time
clock timezone us Eastern
ntp
 server x.x.x.x
From there you can schedule the restart via reload at xx:xx:xx xx-xx-xx for the time and date.
We have 08080e deployed and will be doing the same.
Justin
Esteemed Contributor II
Always consider your feature function needs.  Version trains run parallel and add fixes, etc.  If you don't have a problem, why upgrade?  If it ain't broke...
