Does the ICX7850 switching platform or the ICX platorm in general support a 10GB baste SFP+ transceiver for copper connectivity?
ICX platform and 10GB base T transceiver
3 REPLIES 3
david_chavarri1
If you check the datasheet here: https://www.commscope.com/product-typ...
It has a link to the supported optics for the platforms.
I have this but was hoping an Engineer would get this and have some insight into possible supported / unsupported transceivers as most 10gb sfp+ transceivers work on the ICX platform including non Ruckus/Brocade transceivers.
simon_pollard
Contributor II
Hi Tim
Only the Ruckus 10G-SFPP-TX-A optic is tested and approved for use in the 7850. Third party optics should work but are not guaranteed https://www.commscope.com/globalassets/digizuite/62109-optics-advisory-note.pdf
Simon
