02-13-2024 08:28 AM
Hi
I've been seeing an odd problem for a while and I was hoping that it would be fixed in 9.0.10j but unfortunately it hasn't been. I'm seeing this behaviour on both a 7150-C10ZP and also a 7150-C12.
Following a switch reload the running configuration looks ok but after a while (anything between 1 and 7 days) the DHCP configuration dissapears from the running config. The start-up config looks fine unless I wr mem in which case the DHCP config will be erased from there as well.
This is what the configs look like today following a reload yesterday;
Start-up config;
Running config, the DHCP server configuration in lines 180 to 214 has dissapeared;
Anyone else seeing this? Or any idea what's causing it?
Unfortunately I don't have access to a Ruckus partner or the ability to raise a support ticket (I'm a home user) so hoping someone here will have some useful insights.
