10-20-2022 03:04 PM
When I try to upload the firmware to the switch it will error out. I have tried through SmartZone, TFTP, and flash drive with no success. Yes, I downloaded it several times and even tried a different version but it still will error out.
telnet@xxxxxxx#copy disk0 system-manifest FI08095h_Manifest.txt secondary
Parameter Validation Successful
Manifest file Download Done
Signature Download Done
....Signature Download failed
Manifest Download Failed
telnet@xxxxxxx#copy disk0 system-manifest FI08095h_Manifest.txt primary
telnet@xxxxxxxx#copy tftp system-manifest 10.50.0.133 FI08095h_Manifest.txt primary
..Manifest file Download Done
..Signature Download Done
telnet@xxxxxxx#copy tftp system-manifest 10.50.0.133 FI08095g_Manifest.txt primary
10-21-2022 06:07 AM
I am not sure exactly what is happening there, but it isn't liking something with your folder/manifest. I would say 99.9% of people just use the singular UFI image for upgrades. If you don't specifically need the manifest flavor of upgrade, I would recommend trying the UFI.
Example of TFTP upgrade: (not sure what platform you are on, so image name could be different for you)
copy tftp flash 192.168.1.250 SPR08095gufi.bin primary
For USB:
copy disk0 flash SPR08095gufi.bin primary
Also, can you confirm what code you are coming from? (show version)
10-21-2022 02:47 PM
Here is what happens when I do that.
telnet@xxxxxxx#copy tftp flash 10.50.0.133 SPS08095hufi.bin secondary
Image Download started
..Image Download Done
Image Validation Started
..Application exception
10-21-2022 04:19 PM
What code are you on now? (Sh version)
10-24-2022 03:07 PM
Downgrading from 9.x. I had no issues with the other 40 some odd switches but I have two that refuse to take the firmware.
