Showing results forย
Search instead forย
Did you mean:ย
Max Clients Allowed ZoneFlex7363 & ZoneFlex7762
I want to know the maximum number of clients that can be associated to a ZoneFlex7363 and ZoneFlex7762, ZoneDirector puts the default 100, What would be the recommended maximum?
10 REPLIES 10
WPA isn't recommended. Max usable clients with WPA or WEP will probably be no more than 50 on moderately loaded network. Use WPA2 or nothing at all.
Maybe this links will help somewhat
https://forums.ruckuswireless.com/ruc...
Esteemed Contributor II
7363 and 7962 dual-band APs have 64mb RAM
---- Maximum Users ----
TKIP : 26
AES : 100
Open: 250
7982 and 7372 dual-band APs have 128mb RAM
TKIP : 26
AES : 100
Open : 500
From personal in-field experience in a outdoor 7762-s mesh environment, we've seen that between 28 to 35 clients per AP is a safe bet (performance and latency) wise. This is obviously dependent on certain environmental factors and little interference (physical, rogue, frequency, etc) in your mesh environment.
santiago_zapata
Michael Brado,
What would be the numbers for the models R300, R500, R600, R700 ?. Thanks
On a multiple WLAN setup (on the same AP), with one encrypted and having only 5 clients max, and the other one open, how many clients would I be able to get in the open one?
