Unleashed + CloudPath + SCEP?
atomski
Will SCEP (Simple Certificate Enrollment Protocol) work with Unleashed?
If so, does it require CloudPath, or can it run directly on Unleashed WAPs without it?
Thanks!
4 REPLIES 4
christopher_moh
Cloudpath does support SCEP however Unleashed does not have SCEP capabilities to tie into any type of MDM.
You can enable SCEP in Cloudpath by:
1. Click on Certificate Authority
2. Click on Manage Templates
3. Click on the spanner beside the Template that you wish to use for SCEP
4.  Click on SCEP Keys
5.  You can enter in the SCEP key information in the resulting window.
Christopher
atomski
Thank you, Christopher.
When you say that Unleashed doesn't have SCEP capabilities, do you mean directly/natively?
But you're saying that with CloudPath integration, SCEP will work with Unleashed, correct?
Thanks for the clarification!
That is correct, unleashed doesnt have any SCEP capabilities.  Cloudpath will work with SCEP and unleashed.  Here is a way that Cloudpath uses SCEP with an MDM, in this example intune/end point device manager:  Deployment Guide: Cloudpath ES Intune SCEP Integration | Technical Documents | Ruckus Wireless Suppo...
Christopher
atomski
Much appreciated!
We'll look into CloudPath then.
Cheers 😏
