Severe flaw in WPA2 - cracked
marko_teklic
153 REPLIES 153
"Be professional ... If you have customers that rely on WPA only, then they deserve to be under attack."
Wow Jakob, do you work at Ruckus?
I appreciate they finally took the time to tell us not to worry about anything unless you use features that are turned off by default, or mesh networking . Thanks for assuming most costumers don't care as they would rarely deploy a mesh network, right?
https://www.ruckuswireless.com/rucktionary/mesh-networking-and-smartmesh
http://www.ruckussecurity.com/Smart-Mesh-Networking.asp
http://ruckus-www.s3.amazonaws.com/pdf/appnotes/bpg-wireless-mesh.pdf
You can't flaunt it and be proud of this as a value add, and then chastise customers for using it when there's a security issue you have no urgency to address.
That blog post ("the ruckus room") is embarrassing.  They don't even mention if they have a fix in the pipeline.  Telling their customers who use "mesh" to "turn it off" is stupid.  It's a feature, don't be surprised if people use it.
john_taylor_681
Does anyone know how 7731 bridges are affected by this?
For 7731, P300, and mesh deployments, there is noknown workaround for CVE-2017-13077, CVE-2017-13078, CVE-2017-13079,CVE-2017-13080, and CVE-2017-13081.  However, because Ruckus products useCCMP for Mesh and bridging connectivity, exploitation of these vulnerabilities ismade significantly difficult, as per Section 6.1 of the KeyReinstallation Attacks: Forcing Nonce Reuse in WPA2 report.
