Severe flaw in WPA2 - cracked
marko_teklic
153 REPLIES 153
robert_lowe_722
Contributor III
My issue is more a fact that the advisory doesn't state when a fix will be available. How can i go to my customers with anything unless i can give them a timescale on firmware patch?
kari_hyv_nen
This is my first touch with Ruckus.
A month ago, I inherited a position in a company where the wireless network is done with 6x Ruckus R500 Wireless APs.
Yesterday I contacted Ruckus support and they promised firmware by the end of the day. I have to say, that first impression I got from Ruckus is not an enterprise class and will probably move to ubiquiti.
Well, you better get used to reboot your AP's from time to time then..
I have no problem rebooting APs every now and then. I do have a problem not knowing if/when my network is secure.
Just to be clear here, any Ruckus update will not secure your network. It will fix KRACK vulnerabilities with regards to mesh and the use of 802.11r. There are much broader steps that are required to ensure your networks are secure like updating all clients to ensure they have had their respective KRACK patches applied, after all the majority of the vulnerabilities are client based. You should also look at implementing an WIDS/WIPS system (be it the embedded solution of a controller or standalone) to alert against malicious rougue AP's as this will be a tell tale sign of a potential attack using KRACK.
Here is a good URL on availability of client device patches: https://www.bleepingcomputer.com/news/security/list-of-firmware-and-driver-updates-for-krack-wpa2-vu...
