Limit devices in Cloudpath to one per user
We have done some testing with Cloudpath and you can limit the devices per user until you want to set it to one. With the workflow set to one device per user it actually allows 2 per user. We are working with a school and they want to restrict students to one device only. Is this a feature or is there a way to clamp it down to one device?
2 REPLIES 2
abhi_maras
Hi Robert,
This is a bug when device count set to one, the fix will be available on the maintenance release of 5.0 which is slated to be available by end of this month.
Hi Abhi thanks for the answer, just looking for an update but can't seem to see any info on new version or updates yet. Has this been fixed or is it still in the pipeline?
