Disable captcha in CloudPath workflow ??
majedfivb
Hi ,  May I know how to disable  captcha in CloudPath workflow ??  Running software 5.11.5462 ...
Only available options are Captcha & Recaptcha ...
3 REPLIES 3
James
RUCKUS Team Member
Are you using guest access via sponsor approval?
If yes, does the end user receive verification code via email/ SMS, from the On board cloud email/ SMS service ?
Guest access via captive portal , the guest should enter his/her mobile then receive SMS .
James
RUCKUS Team Member
Please check if you see the following under the "CAPTCHA" section:
If so, as mentioned in the screen shot, CAPTCHA/ reCAPTCHA distinguishes between human and machine input protecting against spam and automated attacks. To disable CAPTCHA/reCAPTCHA please configure your own SMS and/or EMAIL server in Administration->System Services.
