Cloudpath vs RuckusCloud
alex_2dsb26tkdv
what is the difference between CloudPath and Ruckus Cloud WiFi? Does CloudPath feed into Cloud WiFi or there is integration between two systems?
2 REPLIES 2
fred_bred
Ruckus Cloud WiFi allows you to control your wireless network remotely. Ruckus Cloudpath Enrollment System (ES) software is a security and policy management platform that enables IT to easily and definitively secure the network, secure users and secure wired and wireless devices.
And yes they work very well together.
supriya_pradeep
There is integration between Cloud Wi-Fi and Cloudpath. You can refer the How-To guide available on the Ruckus Support site for details on the integration.
