06-06-2022 07:26 AM
Hi
I have installed the latest Android Swipe app, and when I try login even using the vSZ Controller IP address, the Login Fails. I have ensures ports 8443 and 7443 are open. Any other suggestions. ?
06-06-2022 08:14 AM
Can you please share the vSZ version and swipe version in use. Also what is your device type and its OS ?
Best Regards
Vineet
06-06-2022 09:29 AM
Hi.
vSZ 5.1.2.0.302 and Swipe 2.6.38.7
Device is android Samsung a32
06-06-2022 09:30 PM
The swipe is on latest version so I would test this myself/check this internally and get back to you.
Best Regards
Vineet
