SmartCell Insight APIs document
dmitry_ivanko
Hi guys,
this document describes that the SCI has northbound API http://a030f85c1e25003d7609-b98377aee968aad08453374eb1df3398.r40.cf2.rackcdn.com/datasheets/ds-smart...
I can't see any information about API at https://support.ruckuswireless.com. Where can I find the document that describes this API?
Image_ images_messages_5f91c3e4135b77e2478cf9dc_cc35745130054b3dc7add851d79808db_RackMultipart20160114281291snb-08161587-1e35-4777-9568-15105726c86f-1372888566.jpg1452756338
2 REPLIES 2
shimshim
There's a reference implementation of an API client included in SCI 1.4
It is located in /opt/ruckuswireless/sci/scripts/oss-api.php and you can simply run it to pull data, and even upload it to some remote FTP server.
Note: The API is for SCI's canned reports, not Custom Reports ("Analyzer Report"). Custom reports are essentially a GUI that translates dragging of fields on the screen to dynamic SQL queries - the API is thus SQL in that case, and you can simply query the DB directly, the same way the Analyzer Tool does.
dmitry_ivanko
Thank you.
