zoneDirector and captive portal of pfsense
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
01-09-2015 03:53 AM
Hello guys, I'm new here and would like some information about the ZoneDirector settings.
Work in a place where we use as pfSense firewall. We also use the captive portal of pfSense so that users can connect to the wireless network.
We currently have a few access points of tp-link.
In one last purchase, we acquired 4 ZoneFlex R300 and the ZoneDirector 1100.
What I would like to know:
1. How do I set the ZoneDirector 1100 for my users still do authentication on the captive portal of pfSense?
2. I can use the ZoneFlex R300 directly on my network without using the ZoneDirector?
Thanks in advance!
Thanks in advance!
2 REPLIES 2
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-12-2015 05:35 AM
hi Elias,
I will try to answer your questions:
Never used PFsense, I am not sure whether this will work perfectly or not however still give it a shot and let us know the outcome. You can use hotspot WLAN where you can redirect ur unauthenticated users to PFsense webpage for auth. Take a look at below screenshot:
http://prntscr.com/5rjte2
2. I can use the ZoneFlex R300 directly on my network without using the ZoneDirector? Yes. You can use R300 as standalone AP without ZD.
Hope this helps.
Hope this helps.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-22-2015 03:50 AM
Thank you for the answer!
