zf7363 can't connect to ZD1000
I have a ZD1000 with licensed AP 12.
Already a r300 and and a zf7363 connected.
When i connect another zf7363 i have no connection for the 3th one.
Also a 4th and 5th do not have connection.
The 3th, 4th and 5th is comming from a working network.
16 REPLIES 16
Yes it was managed bij a vSZ.
When i look on the ruckus site (https://support.ruckuswireless.com/products/21-zoneflex-7363#firmwares) i only see till version 100.x and not 104.x
Can you send me a link to the firmware?
Anusha_Vemula
Community Manager
Community Manager
7363 is an EoL AP. So, we do not have 104.x firmware released for it.
You can upgrade the AP to the ZD's image with the below process.
1. Login to CLI/SSH of ZD using any tool like Putty,etc.,
2. Follow the below commands.
ruckus>en
ruckus#config
ruckus(config)#sys
ruckus(config-sys)#ftp-anon
ruckus(config-sys)#end
3. Browse ftp:// IP address> and select ZF7363 folder. Save the file with name rcks_fw.bl7 file.
4. Upgrade the AP using this firmware and connect it to the network.
AP should auto discover ZD if there are on same L2 network and should connect.
-Anusha
When i make the ftp connection i see a lot of maps.
One of them is the zf7363 map with a 9.10.0.0.218 map
In this map there are 6 files. All the files are 1 kB
Also the rcks_fw.bl7 file
I i upgrade the AP with this file i get a error
"Bad image size"
What can i do?
what Firmware are you running on the ZD1000? Maybe i an send you the FW to localy update the AP
Firmware of the ZD1000 is 9.10.0.0 build 218
