unable to login in wifi settings 192.168.1.100
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
07-24-2019 02:27 AM
my devices are connecting to wifi zoneflex 2741 802.11 g but the problem is i unable to find login page 192.168.1.100. How to login from any other ideas plz let me know.. ur responce will be appreciated. Thank you
6 REPLIES 6
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-24-2019 02:29 AM
Hi There,
The default login ip is 192.168.0.1. If you have changes it, try pinging that IP first and see if you get a response.
-Ankush
-Ankush
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-24-2019 02:32 AM
There is no reply from 192.168.0.1 and also 192.168.1.100 aswell .. please help me..
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-24-2019 02:36 AM
Unable to find the ip of the wifi login, earlier it was 192.168.1.100
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-24-2019 02:43 AM
Are you on the same subnet as AP? If yes, then use IP scanner and see if you find AP's MAC and corresponding IP and then try logging into it with its IP. If you still cant find it, then resetting the unit is only option you are left with. But be careful with its warranty!
