turn off 5ghz
admin_boston_co
is there a way of turning off the 5ghz channel so its not physically transmitting? we are using a mixture of aps with a ZD3050 director.
9 REPLIES 9
andrea_coppini
Contributor II
Create a WLAN group with all SSIDs disabled, assign it to the 5Ghz radio on the AP Group.
The main question is - why would you want to do that?
alan_rothenstre
Contributor
You can turn off the WLAN Service under the Access Point Configuration and disable all of the channels.
max_o_driscoll
Valued Contributor
As per Alan R suggestion...screenshot attached:
Note: this as a ZD1125 so might look a little different in your case
go to
Access Points
Configure
tick override
untick all the channels in 5Ghz.
should do it.
Image_ images_messages_5f91c42e135b77e2479a63b1_aa68c89f5868eb754c907c032e0dad1a_RackMultipart201605191126751ay-7aa914a4-e9d1-44ec-b95d-b73616795dd2-1469498678.jpg1463668964
tried that and it wont apply it. says choose radio channel. if I add one channel it lets me apply it.
