ssid visibility ZF 7321
oleg_klyuchniko
Hello I've bought AP a few month, all work correct . Now I have a problem with SSID visibility. When I choose 2.4 GHz Wireless Mode and reboot device, SSID is disappear, then I'm switch it to 5 GHz Wireless Mode and is stays visible and clients can connect. What you could recommend me?
2 REPLIES 2
oleg_klyuchniko
Next strange thing, after one hour of stable working on 5 GHz connected devices lose randomly: Windows Phone 8 doesn't see SSID, IPhone 5 see and work correct, notebook with Wi-Fi adapter Intel Corporation PRO/Wireless 3945ABG see SSID but connection drop every 10-15 seconds.
In logs only
"daemon.info hostapd: wlan0: STA 00:1b:77:89:5f:5b WPA: pairwise key handshake completed (RSN)" before disconnect.
keith_redfield
Valued Contributor II
Hi Oleg,
Unfortunately it sounds like you might have a hardware fault. Please contract Ruckus Support for further diagnostics. https://support.ruckuswireless.com/co...
If you have not already done a hard (factory) reset, that would be the first step. Refer to the quick-start guide for instructions.
