r770 how to setup 6 GHz wifi
Teudis
Hi I can't seem to find any how to's on setting up the wifi 6 of the r770. Can someone point me in the right direction please. I know it's accoplished via the CLI but where is the documentation ?
9 REPLIES 9
Out of curiosity as you are running standalone, does unleashed not support the R770? seems like that might be an easier way to configure it.
ckhlee
Can I disable the 6Ghz in R770 to save the PoE power so that the PoE+ switch can still operate?
Teudis
Hi ckhlee, yes I suppose you could disable the 6GHZ radio with
set wlan16 state down
But I would also change the POE power setting with
"get power-mode"  to list the info, then to set it use which ever poe power setting you wish below is what I have on one of mine...
rkscli: get power-mode
PoE Configured Mode : Auto
Power Consumption Status : PoE Injector
USB Status : Disabled
OK
rkscli: set power [double tab to get the extra info]
Commands starting with 'set power' :
set power-mode : set power-mode {auto|af|at|bt5}
-- Change 802.3 PoE Operating Mode
rkscli: set power-mode [auto|af|at|bt5]  BT5 being the higest
Hope this helps you.
ckhlee
Hi Teudis, Thanks. After disabled 6Ghz, once we set the R770 back to power mode at AT, would the antenna power distorted or can still sustain around ~22db?
Teudis
Hi again, once the power mode is adjusted then the power outputs of the radios will change, according to the official chart at AT power mode the max power is 16db for 2.4ghz and 15db for 5+6Ghz.
