01-20-2021 11:06 AM
I can start an SSH session to an R300 using these commandlets:
PS C:\WINDOWS\system32> $ruckussession = New-SSHSession -ComputerName 192.168.5.2 -Credential $cred
PS C:\WINDOWS\system32> Invoke-SSHCommand -Index $ruckussession.SessionId -Command $commands
But whatever the $commands, this gives output:
Host : 192.168.5.2
Output : {, Please login: }
ExitStatus : 1
This seems to be the same thing as when logging on via putty: One has to login al thougt credentials are sent with starting the SSH session. How can I overcome this?
01-20-2021 12:44 PM
Hi Stephen,
This is expected, because Ruckus AP CLI prompts below information when you try to SSH.
Login as
Please login
password
In "Login as" prompt, you can feed any dummy data, but actual login username is required on "Please login" prompt.
Refer the below login output from putty.
login as: admin
Please login: admin
password :
Copyright(C) 2018 Ruckus Wireless, Inc. All Rights Reserved.
** Ruckus T750 Multimedia Hotzone Wireless AP: xxxxxxxxxxx
rkscli:
Modify your login commands and add the context for "Login as", and it should work.
RUCKUS Networks, CommScope!
01-20-2021 12:53 PM
@syamantak_omer thanks for your reply.
I know how to log on interactively, e.g. via PuTTy. But via powershell SSH session, I cannot get it working. What do you mean exactly with: Modify your login commands and add the context for "Login as"? How can I do this in the powershell script?
Stephan van der Plas
01-20-2021 01:31 PM
This works:
#$cred = Get-Credential
$sshshellstream = New-SSHShellStream -Index $ruckussession.SessionId
$sshshellstream.WriteLine('super')
$sshshellstream.WriteLine('password')
sleep 2
$sshshellstream.WriteLine('get station wlan10 list')
sleep 2
$sshshellstream.Read()
Thanks for your help. Now I can use this in my Domoticz system for presence detection.
01-16-2023 10:52 PM
Hey there, I'm facing the same problem, but trying to connect via Python (Paramiko library) or even Putty-CLI -> where both don't work! When trying manually via putty session it works as described:
1.enter dummer or any USERNAME
2. enter real USERNAME
3 enter PASSWORD
Bun intention is to automate it.
Many thanks for any advise how to solve this
Mario
