how to get searial number for rucks controller? and how to activate all my Ap's leagaly..is there any payment to do
Rucks Aps
2 REPLIES 2
martin_martin
Valued Contributor
Hi Hashith,
You can login to the CLI or console with the admin user and type "show version" this will show the serial number of that controller, if you have multiple check each controller.
On the AP's you will need an AP license to have AP's connecting to the controller.
Best is that you contact your Ruckus sales person or Ruckus partner they can explain that to you in detail.
Regards
Martin
Ankush_Chandan
RUCKUS Team Member
Just to add, the command depends upon the type of system. For Ruckus Zone Directors, command will be #show sysinfo
