Showing results forย
Search instead forย
Did you mean:ย
add T300 AP that is running 100.x code to the existing SZ 100 Controller
How do i add T300 AP that is running 100.x code to the existing SZ 100 Controller because it is not recognizing the "set scg ip " command?
3 REPLIES 3
karthik
Contributor
set scg ip command is available in AP104.x.
Upgrade AP to 104.x to issue this command.
Karthik.
What happens when i restore to factory settings an AP that was upgraded from 100.x to 104.x, does it go back to 100.x or will remain 104.x?
it remains 104.
