ZoneDirector 1200, smart mesh and different APs
krzysztof_gagac
I am planning to use R510 APs in smart mesh but I would like to use r310/r300 normally connected to the network. Will this all work with ZoneDirector 1200 ?
10 REPLIES 10
martin_martin
Valued Contributor
Hi Krzysztof,
R300/R310 don't support Mesh
Kind regards
Martin
krzysztof_gagac
I'm aware that R3xx does not support Mesh that's why I will use R510 for Mesh. I just want to use R310 as standard access point. Question is, will zone director be able to manage r510 in mesh and r310 in non mesh mode?
monnat_systems
Valued Contributor II
Zonedirector will be able to manage all your AP's however when it comes to handling R510 Mesh AP, there has to be a similar type radio AP as Root AP.
R310/300 cannot support mesh hence won;t be able to handle R510 as mesh AP.
krzysztof_gagac
Okay so if I connect R510 in mesh and leave R310 connected by ethernet in a normal mode it will all work.
Simply saying I want to have 10 R510 in smart Mesh with 2 Root APS and 10 R310 connected by POE working in normal mode totally independent from mesh. I just wanted to make sure that there will be no issues with ZoneDirector.
