ZF 7363 New AP login credentials don't work
andy_copsey_680
We have just purchased an unopened 7363 AP from ebay and are unable to login to it using super and sp-admin even after ensuring it has had a hard reset. It also doesn't seem to assume the fixed IP address of 192.168.0.1 so we are trying to configure it after it has DHCP'd its address.
We have tried chrome, IE and firefox and the result is the same - the login page blanks the username and pw entries but we get no further.
Is it likely that it has some other hard coded username/PW combination?
Help!
2 REPLIES 2
monnat_systems
Valued Contributor II
Hello Andy,
Please refer to live thread on something which is applicable to you too
https://forums.ruckuswireless.com/ruc...
Best of luck and cheers
andy_copsey_680
Hadn't spotted that. Same problem exactly so will watch and see.
Cheers
