I am planning to supply WiFi for a large public event, about 10000 people present. I estimate that at least half will connect and use the WiFi service, this event will be hosted in a remote area and I only expect small amounts of interference, also the traffic levels will be small ( facebook, simple browsing )
I do have one ZD3000 with 25 Ap license and ten R700 access points, I am not sure about the client limit on the ZD3000 because I noticed that there is a 5000 clients limit but didn't understand where this limit applies. This limitation applies only to authenticated clients or the total number of clients regardless if they are connected to a open network ( no security or captive portal at all ) or using some kind of encryption or authentication ?
At this event I will host two WLAN's: one encrypted with WPA2 ( no user database, only a simple password ) that will host about 100 clients and one open network that will host the public with no encryption or password ( planning to use Vlan pooling in order to break the broadcast domains into smaller chunks ).
Because at this moment I only have 10 x R700 I am planning to get ten more in order to support the clients. I never tested one R700 at full capacity, is this AP capable of the 500 clients stated in the data sheet ? Will the performance degrade very much ?
Thanks !
