The number of AP is very clear in the specs, as for the number of supported clients this is specified very ambiguous. On the main page of the product it is stated "Concurrent Station Up to 10,000" this is not always true, it depends on the license you have, Ruckus should clearly state those limitations ( is this a marketing glitch ? ). Also should clearly explain when this limitation apply, for authenticated clients, for open clients, for what ?
Consider the following, I have the ZD3025 that have 25 licenses and another 25 R700 access points, let's assume one R700 can support 300 clients, this means a possibility of 7500 clients. In this case the ZD3025 will limit my capacity to 5000 clients and in order to exceed this limit I should pay a useless license of AP's that I will never use ? See document here:
https://support.ruckuswireless.com/answers/000001444I think this limitation should be clarified and clearly stated on the product specs.
