ZD1200 on 9.10.0.0 build 218 Firmware on accepting R710 on 100.2.0.0.336 Firmware
Hi Team,
Today i connect our newly acquire R710 which is on 100.2.0.0.336 firmware on our network which have ZD1200 on 9.10.0.0 build 218 Firmware and it seems the ZD is not liking it and now the R710 is in disconnected state and on the event logs i can see
2016/02/10  13:57:47MediumModel[r710] is not supported; connection request from AP[00:00:00:00:00:00] refused. I'm wondering if upgrading the ZD firmware to 9.12 will help...
4 REPLIES 4
martin_martin
Valued Contributor
Hi Chennai itsupport
Yes the line [r710] is not supported; does the trick.
So please upgrade to a later version so that the R710 is accepted.
Kind regards
Martin
Thank you Martin .... will upgrade it to ZD1200 9.12 (GA) Software Release
upgrade it to 9.13.1.0 build 11 the recommended version
Upgrade it 10.x then r710 ap will connected and ur configuration will not hamper go ahead
