XX02 vs. US02 part #s?
mark_davis_qqf9
-XX02 vs. -US02.  What is the difference?
Looking at R320s.
7 REPLIES 7
mark_davis_qqf9
Thanks Phil.  I purchased 4x R320s with -US02.  I learned my lesson by buying the top-of-the-line with the R700 that now isn't supported by unleashed - never again will I buy the top of the line from Ruckus -- I would have been better off to have an R500 or R600 that actually supports unleashed today.
-mark
phil_coverdale_
Hi Mark,
Thank you for choosing Ruckus again.
The R700 AP was the first of the 802.11ac Wave 1 access point from Ruckus.
The R500, R600 and other 802.11ac Wave 1 access points that followed use a different CPU.
Please let us know if you need any further assistance.
Phil.
mark_davis_qqf9
Thanks for the detailed info Phil.
So, the issue is that the Ruckus S/W dev team doesn't want to port the unleashed code to the older CPU?  I have to believe that the memory, FLOPs, Ops, CPI/IPC, clk, freq, process, ISA, etc, are all fine with the older CPU for something as non-compute heavy as unleashed...I'm not asking you to do machine learning/deep learning training on the thing...just support unleashed.
Thanks, -mark
Type a product name
