What is the password for configure.me ssid after factory reset on R510?
kai_cheung
I have an R510 that was originally Unleashed, then flashed to run on my Cloud WiFi network and have now removed the unit from the network.  I'd like to flash this back to Unleashed and have done a factory reset by holding the reset button for 10 seconds.  I now see the configure.meXXXXX SSID but it's asking for a network password to connect to that SSID.  Is there a default password?  I thought that there wouldn't be a password requirement at all.
31 REPLIES 31
Esteemed Contributor II
Hm, try resetting it again... but I'm not sure that your AP will have Unleashed after it connected to the Cloud, where it would get SmartZone image installed.
A true Unleashed AP advertising configure.me-xxyyzz should not require a password, and should allow browser access to "unleashed.ruckuswireless.com" URL.
kai_cheung
Thanks, have tried resetting 3 times and the configure.me ssid is still requesting a pw.  I fear this R510 may now be a brick as I can't log into it to flash back to Unleashed.
If you connect with cables, can you ping 192.168.0.1 address?
@michael_brado i am not able to log in through wired also.
