04-19-2017 02:59 AM
08-23-2018 08:53 AM
To make this work I defined a vendor class ID with the ASCII characters "Ruckus CPE". I then created a predefined option in the class named option 43 with code 006. Then I created the scope option. Using the advanced tab in scope options I chose the custom Ruckus CPE vendor class and predefined option I had created and entered the two controller IPs with a comma between them in the ASCII field.
If your using ZDs use code 003 when creating the predefined option in the vendor class.08-24-2018 09:46 AM
04-15-2020 03:28 AM
