Using T300 outdoors with R600 indoors. Are the T300 the closest outdoor equivalent to the R600?
justin_watson_4
I am planning a network environment, there will be roughly 8 x R600 and 2 or 3 of the outdoor equivalent. I know the T610 does not support Unleashed and appears to have higher specs than the R600, is the T300 the closest match?
3 REPLIES 3
chris_nicholson
AC vs AC-MU
Why would you use Unleashed for that?
That's like 11 Access Points and you won't be able to turn of radios, or SSIDS on radios if you go Unleashed.
But a T300 is 2x2 while the R600 is 3x3.
justin_watson_4
Unleashed is what was used when 5 R600s were set up at a different location after it was recommended. It worked well there so I was planning to use it again. Is there a better alternative to use outdoors?
chris_nicholson
Give it a try with Unleashed. However... if you find you need to disable the 2.4 radios on some of your APs... you are going to have problems. If you want an SSID on one ap and not another... more problems.
If you had 3 APs... you would likely not see any of these needs. But up at 11... you might need more control. At that point you are in ZoneDirector land.
