Upgrading single R510 from Unleashed to standalone issue
Hi Experts,
I have one R510 AP and I want converted to standalone mode, I have reset it and connected via 192.168.0.1 on internet explorer and tried to upgraded from local but for the moment I face with this message and doesn't let me to upgrade from local
Image_ images_messages_619b691b14a66e5df7503c72_e347ec57a975f7c9b6d872cabaec137c_Capture111-b2dc60a7-fa5b-4ea4-8552-0b3cef6fa93f-1885519998.JPG
and I have also tried to upgrade online but again I face with this message:
Image_ images_messages_619b691b14a66e5df7503c72_9d73b0cd325443aba88c287176189362_Capture2-437cd660-904a-4c2c-ae3a-91b0c1c923ab-887736479.JPG
Do you have any ideas or solution?
The AP current firmware is: 200.7.10.202.94
Thank you for sharing your experiences,
Best
Ghasem
20 REPLIES 20
syamantakomer
Community Admin
Community Admin
Hi @ghasem_ashjaei ,
Try to upgrade from controller prompt and not ap-mode, see how it goes.
Using TFTP
ruckus> en
ruckus#
ruckus# debug
ruckus(debug)# fw_upgrade -p tftp  -s 192.168.2.1  -n AP_firmware_filename.img
Using FTP
ruckus(debug)# fw_upgrade -p ftp -s username:password@192.168.2.1 -n AP_firmware_filename.img
Syamantak Omer
RUCKUS Networks, CommScope!
Follow me on LinkedIn
@syamantak_omer
Thank you for your comment,
I tried these command and still no luck,
ruckus(debug)# apfw_upgrade -p ftp -s admin1:admin1@192.168.0.4 -n 1.bl7
 ** Starting CLI Upgrade  **
        Protocol  : ftp
        URL       : ftp://admin1:admin1@192.168.0.4/1.bl7
----->Ruckus Wireless suggest you go to backup ZD setteings first
----->y: contintue upgrade; n: leave here to excute bakup command <save-config> ;
----->Please select one from above
      [y|n] enter>------------------------------------------------------------------------
 ** Checking if memory is sufficient **
----->Sufficient memory to perform upgrade
 ** Downloading AP patch image **
----->Downloading image failed (code:6)
        Please check your network connection
        as well as ftp server, and try again
 ** Upgrade failed, please try again **
apfw_upgrade "-p" "ftp" "-s" "admin1:admin1@192.168.0.4" "-n" "1.bl7"
ruckus(debug)#
I have also tried this command:
ruckus(debug)#apfw_upgrade  ftp://192.168.0.4/1.bl7
Hi syamantak_omer
Can you please let me know which Firmware should be download for changing unleashed to standalone ??
Tnx
Ghasem
This is my control info
I want to connect one single R510 AP to this controller
Image_ images_messages_619cc22514a66e5df750879c_e515f63cce9b5772a5d3bee758027fd7_controller-a40dc96b-b5e8-4ffc-8199-c41b7a0a2463-1925267055.JPG
Ratnadeep
@ghasem_ashjaei
Hi Ghasem,
R510 AP is compatible with the above version ( 6.0.0.0.1331) and any Standalone version of R510 is compatible.
If the commands are still not working, I would request you to please create a case with us and one of our Engineers will help you to upgrade the AP to a standalone version, and connect the AP to the controller.
